Chevrolet Equinox
Platform: Theta
2006 3.4L Intake gasket ?
Old Mar 5, 2013 | 11:55 AM
Eric Althouse's Avatar
Default 2006 3.4L Intake gasket ?
Would a bad intake gasket cause a coolant leak?
Old Mar 5, 2013 | 12:14 PM
kevinkpk's Avatar
Yes, and check your dipstick
Old Mar 5, 2013 | 12:38 PM
I checked the dip stick and it is fine. I had the air plenum off the other day and had a little trouble getting it back on because of the gasket. would it leak coolant from there?
Old Mar 5, 2013 | 4:07 PM
tymr287's Avatar
There is an upper & lower intake manifold system on the 3.4's. The lower intake manifold gasket can go bad causing a coolant leak.
Old Mar 5, 2013 | 9:06 PM
ruley73's Avatar
Yes, a failed intake manifold gasket could cause coolant or oil to leak internally or externally depending on which gasket (upper or lower) fails and where it is leaking.
Although it is not impossible, the upper & lower intake manifold gaskets rarely fail on the 3.4L V6 in the Equinox/Torrent. It has a redesigned upper/lower intake manifold setup than the older 3.4L V6 engines used in the Grand Am, Alero, Impala, etc. which were prone to intake manifold gasket failure.
If you have a coolant leak, it is most likely from a bad water pump that is weeping.
Dads Toy
Oct 21, 2011 6:54 AM
gulfcoastjoe
May 4, 2008 12:38 PM
gcahal_az
Dec 30, 2007 6:35 PM
vfilby
Dec 28, 2007 12:53 PM
98greenventure
Jul 27, 2007 10:28 PM
