After market stereo system install
I have a 2007 Equinox and I received a JVC KD-R875BTS stereo that says it is "steering remote ready." I was able to get the stereo in the car and working, but cannot figure out how to get the steering wheel remote to work with it. The harness set that I was given has a wire that has a tag that says "Steering wheel remote" but I can't figure out where it's supposed to connect to. What am I supposed to do with the wire?
There are a few interfaces available to retain these functions. Which one you need depends and which features you are looking to retain.
If you have the factory amplified stereo with the subwoofer, you'll also need to bypass the factory amp. Doing this will disable the factory sub unless you install an aftermarket amplifier to power it. I believe it is possible to install a new radio and retain the amplified system, but it would require some advanced wiring & modification. I am not aware of anyone that has successfully done so.
Thank you! Is there an interface you would recommend just to maintain the steering wheel remote capabilities? It has OnStar in the car, but we did not subscribe to it so I don't need to keep that and as far as other features go, the it's all the basic features
