Coolant Bleeder valve on 2006 Equinox
I broke off the top of the coolant bleeder valve on my 2006 Equinox with the 3.4L engine. The part is NLA from GM and I can't seem to find any aftermarket replacement. I can't be the only one with this problem. Has anyone found a replacement other than the junk yard or some other solution? Thanks.
Replace the whole fitting. Dorman p/n 626-530 is a direct replacement for the OEM fitting (GM p/n 12582446). It's only $18 on Amazon right now. A local auto parts store might have one in stock for around $25.
Just FYI on options if a replacement can’t be located:
1) You can also crack loose the valve fitting to bleed the system. Loosening the fitting a couple of turns provides the same result by allowing the air to bleed out through the threads.
2) The fitting and valve screw are just brass, and assuming it’s removed without excessive damage, could easily be drilled and tapped for a replacement screw of just about any thread pitch.
