equinox 2007 headlights out
2007 equniox low beam head lights just stopped working but when i pushed the high beam lever the high beams
came on but only if i held it low beams would still not work if i let go of the lever when i got home and restarted the car the lights worked like they should 38000 miles
i need some help if anybody knows a fix or that the problem might be
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> It may be time to replace your headlights. Low beams and high beams are usually a different bulb or a different filament in the headlight. The low beams tend to burn out first, because they are used more. This is just a suggestion to consider, not a diagnosis. You may want to consider taking the vehicle in for an inspection.
Please keep us posted.
Have a great day!
Louis
GM Customer Service
Have a great day!
Louis
GM Customer Service
Are the low beams out in both daytime running light mode and manual low beam operation or both?
to check the dtl operation make sure its in bright daylight, the car is running, in drive with the e-brake off.
the headlights seem to work ok after i restarted the car but something caused this, i do not know if this is related but sometimes the wiper lever
does not work unless i push it toward the dashboard
David_lee1993
November 1st, 2012 11:06 PM
aelange
June 13th, 2010 8:50 PM
AcousticHoney
Silverado & Fullsize Pick-ups
18
May 30th, 2009 5:46 PM
mentalmom
Equinox
November 26th, 2008 6:05 PM
