Key fob and remote start issues
I just purchased a 2013 Chevy Equinox and since day one I have had problems with my key fobs! It will unlock,lock and the remote start will work then I go to use it a couple hours later and it won’t do anything I then have to put the key in the door and turn key to unlock them once I do that my alarm goes off then the key fob works went back to where I bought my vehicle and they replaced the batteries and it work drove home and within a hour tried it again and nothing someone please help
Buy a cheap kit on Amazon, put the old chip in the new one, cut or take the key out, insert it into your new fob, and put them in your new key fob with a new 2023 Li-ion battery and you are good to go. If lost (hopefully you have a spare fob) same deal only you'll need new chip. Insert old key fob into the ignition key, remove, insert new fob . and it it is all re-programmed. .
