Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
Leaking water and I think it's my fault
Old June 28th, 2020, 4:05 AM
garridd1972's Avatar
Default Leaking water and I think it's my fault
My 2006 Equinox is leaking water I'm the front passenger side. I have replaced the heater core, AC HVAC, the blend door, and plus I've made sure the AC drip was free of trash. The only thing I can think of is I have holes in the box that holds everything on the passenger side. Is there anything I can put on it to seal it up?
Old June 28th, 2020, 5:53 AM
oilcanhenry's Avatar
Your A/C drain should allow any water or coolant to drain out of the C/C box. What is liquid leaking out?
Old June 29th, 2020, 3:25 AM
On the passenger side in the corner I miss and drill some holes in there so now that's where it's leaking. Was doing something stupid watching a video on YouTube trying to fix my blend door. I ended up drilling a hole through the plastic that it holds the AC and heater core and busted the AC.but I did clear out the hose that the water comes 6 of
Old June 29th, 2020, 9:35 PM
Your entire message did not come through properly. Did you damage the A/C evaporator or the heater core? Is your engine coolant leaking? R-134A A/C refrigerant won't leak as it turns into a gas at normal atmosheric pressures.
Old June 29th, 2020, 9:55 PM
ruley73's Avatar
Check the cabin air filter. It might be in dire need of replacement. Normally, this doesn't cause a water leak, but this is easy to check and replace if necessary.
Old June 30th, 2020, 12:11 AM
I suppose that's a possibility, but my 1998 K-1500 Chevy has no such cabin air filter and it's never leaked any water into the cabin. In warm non-rainy weather, I doubt that this is the OP's issue.
Old June 30th, 2020, 7:53 AM
I poked a hole in the box through the AC EVAP. So that's where my leak was coming from, but my cousin came by this morning and help me seal with some proxy and aluminum tape. I do appreciate you guys trying to help though
garridd1972
Equinox
June 28th, 2020 4:05 AM
RockyS.
Silverado & Fullsize Pick-ups
17
July 11th, 2016 10:58 PM
Matt Baxter
December 18th, 2015 9:20 PM
Earl Ricky
September 14th, 2010 10:59 AM
Quick Reply: Leaking water and I think it's my fault
