Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
Stabilitrak Error and Engine Code
Old September 5th, 2017, 12:21 PM
sam_moening's Avatar
Default Stabilitrak Error and Engine Code
I had the "Service Stabilitrak" and "Service Traction Control" message come up but that was it, no performance issues. So I waited till a check engine code popped up and these are the codes that came up.
These were what Advance Auto said
C0561 - System disabled Information Stored invalid serial data recieved - invalid serial data recieved.
P1779 - Torque Delivered Signal
P0404 - Exhaust gas recirculation conteo circuit range/ performance (in the top right corner it says ECM)
P0404 - same description as abovebut in the top right it says Mod $00
Took it to O'Reillys also and this was the one code that showed up different
U0073 - Control module communication bus off
So I changed out the EGR valve hoping all these problems stemmed from that and pulled the cables to the battery to try and reset the codes. Started it and drove about 30 miles and the code was gone and then they popped back up with the check engine light/codes and the "Service Stabilitrak" message.
Anyone have any thoughts on where I can go from here. I drove it for probably 75 miles more and nothing seems to be running wrong.
Thanks in advance
Sam
