05 Nox Inside Fan/Blower ?
Why is it that the inside cabin fan/blower is cutting off briefly and then comes right back on when the ac is on ? Fan speed is set to 3 when this occurs.
Is something getting ready to fail ?
Thanks for any suggestions.
After utilizing Google I was able to find more info. However in the link I'm going to post shows the multiple plug drivers side being bypassed and a wire being spliced on a 2006 Nox. If this is indeed my problem are the 05-06 nox's the same as far as the wiring to the multiple plug and blower ? Also with the multiple plug being bypassed is that creating another possible electrical issue ? My blower is only blowing part of the time as it still is cutting on and off while on at any speed. The other day it would not come on at all until I tapped/banged underneath the dash on passenger side and then it started again.
Thanks for any info and here's the link.
2006 Chevrolet Equinox, Blower Erratic / Inoperative
I really wanted to respond to your first post, but the part about it only happening when the fan speed was set to three baffled me. If the blower motor randomly cuts out at all speeds I suspect it has a bad spot in it. It certainly wouldn't hurt to inspect the wiring before replacing the motor though.
The wiring should be nearly identical between 2005 & 2006 models.
Thanks for your reply. Please don't hesitate in replying to my post as I really do appreciate any info obtained by you and others. This thread is really slow as it is.
The reason I noted the 3-speed was because that is the setting that I usually keep it on and that is where I first noticed it doing that.
But now it will do it on any speed.
Today on speed-2 no issues. When I put it on 3 it cut off and then on while sitting in the car in park. I never use the 4 setting as it really blows too loud and hard.
As I mentioned before one day it would not come on at all until I banged underneath the dash on the passenger side.
Hey ruley73,
I'm still having issues with the compressor as it cut's off on long runs but doe's a really good job on short runs and I will take that instead of no ac at all.
I found a couple TSBs (attached below) that you should take a look at before replacing the blower motor.
#PIT3698A_ Intermittent Loss Of A_C Request Blower On Speed 2 3 Or 4 - (Jun 24, 2009).pdf
TSB #03-08-45-003D_HVAC_driveability_issues_check harness.pdf
Replacing the blower motor is pretty straight forward. It's located just above the passenger's feet behind the glove box, and is held in with three screws.
^^^^^OK,
Thanks for the info. I guess I'll start pricing the blower and have it hand once it totally fails. I'll also check the wiring on the drivers side panel and at the blower.
Remember the multiplug was bypassed on the and the wire spliced. Is that a good idea if it is the wire ?
^^^^^OK,
biglg
March 28th, 2008 8:32 AM
