05 Nox Turn off with no warning
![Exclamation](https://chevroletforum.com/forum/images/icons/icon4.gif)
Hi, how are you guys?
I write because I have a 2005 Equinox LT. Two days ago the sunroof drain was clogged and water enter inside. I got Many codes ... But searching here I found a post That Said Have to check under the left pillar .. some kind of electrical connector ... I did .. clean all the connector .. and all was fine .. I did clean the codes with a scanner. All good runs good as always but... ... ! Today, the equinox shut down when I was driving to getting lunch, I did not turn anything .. zero codes nothing. just turns off. After stopping and starting again did so without problems. (no codes) no sign of failure...good so far..but...
Then it happened on my way home again ... went off without any warning.,,,in the middle of the HW..
no codes, not fuses blow.. nada!!
Can anyone tell me what to do or check?![Roll Eyes (Sarcastic)](https://chevroletforum.com/forum/images/smilies/rolleyes.gif)
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Thanks ./////
![Frown](https://chevroletforum.com/forum/images/smilies/frown.gif)
Thanks ./////
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> netmessys,
I am sorry to hear of your frustration with your Equinox. I would like to look into this further, would you please PM me your VIN number? I may be able to offer additional information.
I look forward to your reply.
Louis
GM Customer Service
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
Louis
GM Customer Service
![Thumbs up](https://chevroletforum.com/forum/images/icons/icon14.gif)
Louis
GM Customer Service
Louis
GM Customer Service
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
![Talking](https://chevroletforum.com/forum/images/icons/icon10.gif)
Hey guys!!
I fount the source of the problems... The connector C200 Ip body harness .. has some corrosion and some lines were intermittent.
At this point just has a code p0332 intermittent...
thanks all !!
thanks all !!
Mr. Vann
November 25th, 2009 7:24 PM
