06 equinox heat/fan control lights
I just purchased an 06 equinox and the lights in the fan control and the heat dial went out. what could this be? how do you replace the lights if that is the problem. also the light does not work on the curse control set button on the steering wheel.
Thanx for the help
gMl
Thanx for the help
gMl
did you ever get an answer to this?? i just purchased an 06 equinox with the same prob. the fan dial worked but not the next 2. replaced that entire piece and it still didnt work. think it might be the wiring.
jmarkv
January 24th, 2012 8:21 PM
