Chevrolet Equinox
Platform: Theta
06 Equinox P 0481
Old June 16th, 2018, 9:50 AM
confused's Avatar
Default 06 Equinox P 0481
06 Equinox P 0481 Replaced both fans. Secondary fan pigtail (it was burnt on one terminal) and 5 prong relay under the left front wheel well. Code keeps returning. A/C works fine, temp gauge is fine. Both fans seem to work with the exception of one time they were not on. But A/C and temp were good.
Old June 16th, 2018, 4:48 PM
ruley73's Avatar
There are three cooling fan relays. One for the high speed power source, one for the low speed power source, and third one that switches the fans between series & parallel operation. The relay under the front left wheel well is the series/parallel relay. The other two relays are in the underhood fuse block, and I suspect one of them is bad.
