06 misfire cylinder 5
Nothing in these pictures indicates the coil is bad. The ignition system on this engine uses a waste spark design that fires 1/4, 2/5 and 3/6 at the same time. Knowing that and seeing 0 misfires on cylinder 2 actually suggests the coil is probably fine, but isn't a sure thing. Looking at live data only tells you how often each cylinder is misfiring. It doesn't tell you why. You need to do some real troubleshooting like I previously suggested to find the cause. Pull the # 5 wire off the coil while the engine is running. If you see & hear spark arcing between the coil tower and the plug wire end the coil is fine. Performing a compression check on cylinder 5 should be the next thing you do if that checks out fine. If compression is good, it's most likely a bad fuel injector.
Buy a compression tool first. My uncles 04 sieera 5.3 developed a dead miss on cylinder 4 a couple of months ago. Checked and had no compression. Turns out a piece of metal/aluminum trash got trapped between the valve and seat. End result it burnt a hole in the exhaust valve. Pull the head replaced it and motor runs perfect.
Truck Lovin Girl
March 31st, 2014 8:35 PM
