Chevrolet Equinox
Platform: Theta
06 misfire cylinder 5
Old Feb 7, 2023 | 7:40 AM
ap4u06's Avatar
15 Year Member
Default 06 misfire cylinder 5
i have changed plugs, wires still getting number 5 misfire, could this be ignition coil going bad?
thanks,
ap4u06
Old Feb 7, 2023 | 7:25 PM
ruley73's Avatar
thanks,
ap4u06
Yes, but it could also be a bad injector or low compression. You can rule out the ignition coil quickly by pulling the #5 boot off it and looking for spark arcing between the coil and the wire. The coil doesn't fail very often on these vehicles so a bad injector or bad compression on that cylinder seems more likely.
Old Feb 22, 2023 | 8:20 AM
ap4u06's Avatar
15 Year Member
This was from last night on my scanner live data. Seems that it’s the coil that has gone bad.
Old Feb 27, 2023 | 7:18 PM
ruley73's Avatar
Nothing in these pictures indicates the coil is bad. The ignition system on this engine uses a waste spark design that fires 1/4, 2/5 and 3/6 at the same time. Knowing that and seeing 0 misfires on cylinder 2 actually suggests the coil is probably fine, but isn't a sure thing. Looking at live data only tells you how often each cylinder is misfiring. It doesn't tell you why. You need to do some real troubleshooting like I previously suggested to find the cause. Pull the # 5 wire off the coil while the engine is running. If you see & hear spark arcing between the coil tower and the plug wire end the coil is fine. Performing a compression check on cylinder 5 should be the next thing you do if that checks out fine. If compression is good, it's most likely a bad fuel injector.
Old Mar 1, 2023 | 10:14 AM
ap4u06's Avatar
15 Year Member
So checked all wires to the coil. Has spark to all from the wires. How do I check compression on this vehicle?
Old Mar 1, 2023 | 11:03 AM
Craig0320's Avatar
Buy a compression tool first. My uncles 04 sieera 5.3 developed a dead miss on cylinder 4 a couple of months ago. Checked and had no compression. Turns out a piece of metal/aluminum trash got trapped between the valve and seat. End result it burnt a hole in the exhaust valve. Pull the head replaced it and motor runs perfect.
Hellblazer73
Nov 16, 2021 12:30 AM
Grandline
May 20, 2021 1:58 PM
Invisions1
Dec 4, 2020 6:37 PM
Kickster03
Nov 25, 2014 3:08 PM
Truck Lovin Girl
Mar 31, 2014 8:35 PM
