07 Equinox Poor key remote signal
Do you have any accessories plugged in to the 12V power port such as a cell phone charger? If so, try disconnecting it and see if that makes a difference. GM issued a TSB a few years ago for the reduced remote range issue. In the TSB they suggest removing any accessories from the vehicle to see if it helps. The TSB states that some USB/cell phone chargers, wireless gate switches, and wireless winch switches in particular emit RF interference that affects remote range.
There could also be an issue with the Remote Control Door Lock Receiver (RCDLR). That's the part that receives signals from the TPMS sensors and the keyless remotes. Try pulling the 10A HVAC/RFA fuse from the interior fuse panel for a few minutes to see if that fixes it. If that has no affect the next thing I'd try is to disconnect/reconnect any plugs going to the remote control door lock receiver. The receiver is located in the cabin in front of and below the right rear window near the C-pillar. You will probably need to remove a couple panels to access it. If that doesn't work the RCDLR may need to be replaced.
alicia Krafthefer
June 27th, 2020 8:07 AM
