'09 equinox towing a travel trailer
I have a '09 equinox and pull a 2000lb trailer with a 3.4L v-6 5 sp auto.
does anyone do this?
My concern is the auto trans, and the position "I" on the shifter
Is that like the "tow haul" on a chevy truck??
mine constantly shifts back and forth when going up grades and in a little wind.
the tachometer goes from around 3000rpm going on level plain
then when a load is applied it will go down to 2000rpm like shifting into a
higher gear, then it shifts into a lower gear raising the rpm to 3500 or
almost like in "passing gear" And it will do this constantly. or until i get on level highway again.
I am definately confused.
Phil
Phil
i DONT PULL TRAILERS WITH THE SHIFTER LEFT IN D ON MY VAN I LEAVE THE SHIFTER ON 3 SO THE TRANSMISSION DONT HUNT ALL THE TIME. LIKE THIS YOUR TRANSMISSION WILL BE HAPPY. FOR YOUR CASE SINCE YOU HAVE A 5 SPEED TRANSMISSION I GESS YOU HAVE TO LEAVE IT ON 4. GM AND OTHER MANUFACTURERS DONT RECOMEND TO PULL TRAILERS IN OVERDRIVE
the tachometer goes from travel trailer rentals around 3000rpm going on level plain
DeeZ
July 30th, 2009 12:28 PM
