Chevrolet Equinox
Platform: Theta
2005 Equinox AWD grinding noise need your help.
Old May 2, 2016 | 10:10 PM
Bombadil's Avatar
Default 2005 Equinox AWD grinding noise need your help.
I am having a grinding noise when I engage the AWD. Do you guys have this noise as well on your equinoxs? If not what is the issue? You can go to this youtube and listen to the noise?
Old May 3, 2016 | 9:06 AM
Bombadil's Avatar
Originally Posted by Bombadil
I am having a grinding noise when I engage the AWD. Do you guys have this noise as well on your equinoxs? If not what is the issue? You can go to this youtube and listen to the noise? 2005 Equinox Grinding noise when AWD engages. - YouTube
Updated video https://youtu.be/cPgoEz9Ymd8
Old May 4, 2016 | 7:32 PM
ruley73's Avatar
I didn't hear the noise in the first video, but I did in the second one. I'm not that familiar with the AWD setup, but after reading the documentation I've attached below, I'd suspect an issue with the rear drive module (RDM) located in the middle of the rear axle. I'm guessing either the RDM fluid is low or the clutches in the RDM are bad.
RDM_description_and_operation.pdf
transfer_case_description_and_operation.pdf
rear_axle_lubricant_level_inspection.pdf
Old Jan 7, 2017 | 3:02 PM
Mr5speed's Avatar
Did you ever determine what the issue was, and the resolution? Our '06 just starting doing the same thing today in the snow.
