2006 Equinox ABS/Traction Control Issues
For anyone else coming here to research why, yes, replace the wheel hub assemblies. The ABS part (exciter ring) is going bad and causing the issue. Low-end parts run about $55 each so for about $220 and maybe half a day's work, you fix the problem yourself. If you take it to a garage, expect somewhere around $400-$600 with labor and higher-end parts. Also, if you do it yourself and don't have a code reader, you may need to find someone to clear the codes when done if they remain.
rlnewell
Aug 2, 2017 2:15 PM
umoms
Jun 27, 2011 12:23 PM
