Chevrolet Equinox
Platform: Theta
2007 Chev Equinox
Old Jan 26, 2010 | 6:30 AM
joepoker's Avatar
Default 2007 Chev Equinox
Lift gate stopped working, will not open at all unless emergency latch from inside is pushed. Changed fuse and still not working. Electronic pad instead of mechanical latch. Anyone else had this problem? Hopefully I can fix myself as bumper to bumper warranty just ran out. HELP!
Old Jan 27, 2010 | 3:51 PM
hyson's Avatar
And it's just the lift gate that stopped functioning? Which fuse did you change out?
Old Jan 28, 2010 | 3:38 AM
joepoker's Avatar
It happened after I got a boost and had to change several fuses.
Old Jan 28, 2010 | 9:26 AM
hyson's Avatar
Ok. Can you answer my previous questions? Which fuses did you change out and is it just the tailgate that's nonfunctioning.
Old Jan 28, 2010 | 6:48 PM
joepoker's Avatar
Yes, it is the tailgate that is now the only thing not working. I changed the fused for the radio, turn signals and door locks. I changed the 15 amp fuse for the tailgate and double checked several times to make sure I had the right fuse indicated on the diagram.
Old Jan 29, 2010 | 7:54 PM
joepoker's Avatar
Anyone have any ideas?
Old Jan 29, 2010 | 8:22 PM
hyson's Avatar
Did you check for any blown fuses in your engine compartment fuse block?
Old Jan 29, 2010 | 8:26 PM
joepoker's Avatar
No, is it possible there are fuses in there for the liftgate?
Old Jan 29, 2010 | 9:07 PM
hyson's Avatar
Originally, I thought no. And based off of the wiring diagram, it doesn't appear there are any fuses specifically for that.
I don't think it would hurt to take a look in there just to make sure something goofy isn't affecting the tailgate.
I can't remember but I think if the vehicle is running, you cannot unlock the back gate? I know the tailgate in my Liberty acts strangly like that. I'll have to check my wife's Nox for tailgate restrictions.
Also, have you tried this fix on page 108? Give that a shot.
Old Sep 14, 2011 | 4:47 AM
RyCar's Avatar
Default Fuse for Lift Gate
There is a fuse panel on the passenger side of the center console (to the right of the radio). It is fuse #4. My problem was not the fuse though. The mechanism that contains a motor to release the latch was stuck. I tore it apart and unstuck it. The flat membrane switch that opens the liftgate was also faulty. It is removed easily from the outside by removing two screws.
