Chevrolet Equinox
Platform: Theta
2007 Engine Overheating with fuel gauge and temp gauge inoperable.
Old Sep 12, 2016 | 2:41 PM
Craig Ratcliff's Avatar
Default 2007 Engine Overheating with fuel gauge and temp gauge inoperable.
Gauges spin and then stay at weird angle to readings. Engine fans come on constantly. Already replaced coolant, radiator flushed, replaced temp sensor and thermostat. Alarms went off constantly minutes after starting car, now they don't because gauge is inop. That said the fans still run every time I drive it. If anyone can tell me where the connectors are, I will try disconnecting and reconnecting them just to see if it resolves any faults. I was told the DIC repair would be about $1200, really don't want to go there. Guesswork and not solved it yet. if no solution, then I will have to say thank you for the miles and move on. BTW, had the headlight burn out issue, had the gas tank issue, had the EGR issue, had several other repairs. Might be time to say goodbye to US made cars again.
