2007 Equinox Door Electrical Problem
Hiya all! Thanks for looking at the post and I'll keep it short and simple.
I have an electrical problem with my passenger side front, the power window and the door lock no longer work. But, the power mirror on that side still works. I was wondering if there was a fuseable link that runs power to the door or some other common piece of wiring that I've been overlooking.
I haven't put a multimeter on it to see if there's actually power going to each piece, I've pulled the interior apart to see if a connector leading to the door was separated and found nothing wrong.
Is there an electrical diagram available anywhere I can look at so I know where to at least start looking?
I can tell you for sure that each circuit is grounded in a separate place, before going to their respective switches.
I have attached relevant wiring diagrams below.
2007-2009_Equinox_Power_Door_Locks_Wiring_Diagram.pdf
2007-2009_Equinox_Power_Windows_Wiring_Diagram.pdf
