Chevrolet Equinox
Platform: Theta
2007 Equinox Door Electrical Problem
Old Feb 14, 2012 | 9:23 AM
MrFiXXXit's Avatar
Default 2007 Equinox Door Electrical Problem
Hiya all! Thanks for looking at the post and I'll keep it short and simple.
I have an electrical problem with my passenger side front, the power window and the door lock no longer work. But, the power mirror on that side still works. I was wondering if there was a fuseable link that runs power to the door or some other common piece of wiring that I've been overlooking.
I haven't put a multimeter on it to see if there's actually power going to each piece, I've pulled the interior apart to see if a connector leading to the door was separated and found nothing wrong.
Is there an electrical diagram available anywhere I can look at so I know where to at least start looking?
Old Feb 15, 2012 | 5:15 AM
ruley73's Avatar
Default revised
I'm thinking that a couple wires may have separated in the door jamb within the rubber sleeve. Each of those circuits (power windows, locks) operate in a manner in which the way the power and ground are applied to the device (window motor, lock actuator) is determined by the way the switch is being pressed. As a result, the circuits are wired completely separate from each other with dedicated wires going to each.
I can tell you for sure that each circuit is grounded in a separate place, before going to their respective switches.
I have attached relevant wiring diagrams below.
2007-2009_Equinox_Power_Door_Locks_Wiring_Diagram.pdf
2007-2009_Equinox_Power_Windows_Wiring_Diagram.pdf
funnyguyMI
May 4, 2025 6:10 PM
Joels.blacklab
Dec 27, 2017 7:48 AM
ejkkj
Avalanche
May 17, 2012 9:35 AM
onequickvr4
Jan 26, 2011 1:22 AM
Spydertek
Jul 13, 2005 5:44 PM
