Chevrolet Equinox
Platform: Theta
2007 Equinox key fob
Old September 9th, 2012, 11:46 PM
Fox1311's Avatar
Default 2007 Equinox key fob
07 Equinox the Key fob works when parking and locking the doors. Twenty seconds later the fob does nothing unless you manually unlock the door and then silence the alarm with the unlock button on the fob. New battery on fob and relearned fob through car's menu still the same.
Old September 11th, 2012, 2:39 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Fox1311,
Are these the original fobs or new fobs? Is this a recent issue? Did it start after changing the battery?
Louis
GM Customer Service
Old September 12th, 2012, 6:16 AM
Mine was acting up and I bought one from a seller on Ebay. I got an original GM fob with programming instructions. Works great! There are many of them for sale with much better prices than the dealer.
Old September 12th, 2012, 11:24 AM
Fox1311's Avatar
Louis
GM Customer Service
These are the original key fobs and yes it started shortly after changing the battery.
Old September 20th, 2012, 4:13 PM
Danijal Daca's Avatar
Fox1311,
I have a Camaro and had similar problems as yours.
Have you tried reprogramming your fob? That worked for me
And please do not pay Dealers or Locksmith, they will just charge you to much. Instead you can look for a video on Youtube or google it.
here is a site I just googled for you, hope it helps you out
2007 Chevrolet Equinox Keyless entry key programming instructions - ProgramKeyFob.com
Danijal
Old September 21st, 2012, 11:51 PM
Fox1311's Avatar
thank you i have tried reprogramming it
Old March 15th, 2019, 6:50 PM
Xavier Thompson's Avatar
Hi! Where you able to find a solution to this problem?
I'm asking because I've purchased a set of new programmable fobs and they worked for a while. Not long after they, like the original fobs, quit .
sc4616
November 22nd, 2014 9:28 AM
kcarberry
January 24th, 2014 5:37 PM
triplenickle05
June 25th, 2012 3:26 PM
chevykicksbut
October 23rd, 2010 12:32 AM
Quick Reply: 2007 Equinox key fob
