Chevrolet Equinox
Platform: Theta
2007 Equinox key fob
Old Sep 9, 2012 | 11:46 PM
Fox1311's Avatar
Default 2007 Equinox key fob
07 Equinox the Key fob works when parking and locking the doors. Twenty seconds later the fob does nothing unless you manually unlock the door and then silence the alarm with the unlock button on the fob. New battery on fob and relearned fob through car's menu still the same.
Old Sep 11, 2012 | 2:39 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Fox1311,
Are these the original fobs or new fobs? Is this a recent issue? Did it start after changing the battery?
Louis
GM Customer Service
Old Sep 12, 2012 | 6:16 AM
Mine was acting up and I bought one from a seller on Ebay. I got an original GM fob with programming instructions. Works great! There are many of them for sale with much better prices than the dealer.
Old Sep 12, 2012 | 11:24 AM
Fox1311's Avatar
Louis
GM Customer Service
These are the original key fobs and yes it started shortly after changing the battery.
Old Sep 20, 2012 | 4:13 PM
Danijal Daca's Avatar
Fox1311,
I have a Camaro and had similar problems as yours.
Have you tried reprogramming your fob? That worked for me
And please do not pay Dealers or Locksmith, they will just charge you to much. Instead you can look for a video on Youtube or google it.
here is a site I just googled for you, hope it helps you out
2007 Chevrolet Equinox Keyless entry key programming instructions - ProgramKeyFob.com
Danijal
Old Sep 21, 2012 | 11:51 PM
Fox1311's Avatar
thank you i have tried reprogramming it
Old Mar 15, 2019 | 6:50 PM
Xavier Thompson's Avatar
Hi! Where you able to find a solution to this problem?
I'm asking because I've purchased a set of new programmable fobs and they worked for a while. Not long after they, like the original fobs, quit .
sc4616
Nov 22, 2014 9:28 AM
kcarberry
Jan 24, 2014 5:37 PM
triplenickle05
Jun 25, 2012 3:26 PM
chevykicksbut
Oct 23, 2010 12:32 AM
