Chevrolet Equinox
Platform: Theta
2007 Equinox transmission question
Old Apr 28, 2022 | 12:46 AM
Overlordexo's Avatar
Default 2007 Equinox transmission question
Hello all, so I recently purchased a 2007 equinox with the 3.4l v6 and the aisin aw33-5 transmission. So I am hoping that someone here will know the answer to my question.
The transmission is leaking from the valve body cover on the side of the transmission (front of the engine bay, below the battery box). I have one bolt that the t35 torx head is stripped out on, it's also the hardest bolt to get to as it is right up against the subframe.
I can however, remove the bolt with some vice grips and a hammer - but that will of course ruin an already ruined bolt.
Does anyone know the acdelco part number for those bolts? (There are nine of them I believe) or does anyone know the specifications of the bolt, so that I may try to find a suitable replacement? I can't really just remove one, and go to the hardware store to compare.
Any help is appreciated, thank you in advance.
Old Apr 28, 2022 | 8:12 AM
bearbait's Avatar
Why not remove an already ruined bolt? The only way to fix it is to replace the bolt. Remove it and go to an Auto parts store (NAPA) and get another bolt .Even if it's a hex head and not a torx it should work! Good Luck with your problem
Old May 1, 2022 | 10:25 AM
ruley73's Avatar
The OEM part number is 24220587, and GM's MSRP is $5.28/ea - some dealerships may charge more. As far as availability goes, they aren't discontinued, but no dealership in the whole country has any in stock. Expect to wait 7-10 days for them to ship from the only GM parts facility that has them.
As someone already suggested, you should be able to find a suitable replacements at a hardware store. The thread specs of the screws are M8 x 1.25 x 15.5mm.
Old May 1, 2022 | 10:39 AM
Thank you so much - I had been trying to find the spec for the bolt but had no luck. Now to just go search around and find suitable replacements so I can get this problem resolved!
Thanks again!
boxtruckcamper
Aug 20, 2021 7:53 PM
brokenshadows
May 5, 2014 9:22 PM
danhiman
Oct 3, 2011 8:04 PM
nub
Sep 30, 2009 2:54 PM
Outcastz89
Dec 6, 2008 2:13 AM
