Chevrolet Equinox
Platform: Theta
2008 Equinox wire diagram
Old May 3, 2014 | 8:41 PM
clydemu2005's Avatar
Default 2008 Equinox wire diagram
I am an avionics tech so this is frustrating, my windshield washer pump is shorted and my keyless entry works intermittent. I need a wiring diagram to see if I have two different problems or if they are related, but cannot find one. Please help!!!
Old May 4, 2014 | 11:20 AM
tomwalt's Avatar
From years 2007 and on, the Body Control Module (BCM) controls both, as well as all other locks/lights/ect.
My BCM went bad last winter. Due to required programming, Chevy stealship must replace it. They gouged me for 4 hours labor - even after I told them upon scheduling the appt and dropping it off that the BCM was bad and I needed the BCM replaced and programmed - forgive the rant - it makes me feel better - still a sore subject for me:>)
The Haynes Manual (PN 38040) has very nice wiring diagrams that I used to look this up - the book has been worth the $ (if you plan to keep the Nox).
Old May 5, 2014 | 11:18 AM
Is that part a bus where I can open it up and fix it myself?
Old May 6, 2014 | 8:09 AM
tomwalt's Avatar
With these being your only two issues, I would start with the washer pump and T/S it - there are relays fuses than can be swapped, power/grounds to be checked. The BCM is a ckt card that controls everything attached to the body - locks, windows, ignition lock, tailgate, wipers, etc.
I doubt that the BCM would be bad if you only have these two issues.
** Another thing that causes weird issues is the battery - if your battery is the original, I would replace it - go to Wal-mart and get the exact amperage replacement (if I recall it is an H5 - but you need to verify this)
tranceport185
Aug 19, 2023 11:04 AM
jrobert
Oct 13, 2012 10:01 AM
mike79K5
K5 Blazer
15
May 7, 2011 5:14 PM
Classical Glass
Aug 10, 2010 9:17 PM
fatguy
Sep 30, 2008 3:25 PM
