Chevrolet Equinox
Platform: Theta
2010-2015 Chevrolet Equinox LED Upgrade Bulb Size Guide
Old Jan 4, 2024 | 9:49 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default 2010-2015 Chevrolet Equinox LED Upgrade Bulb Size Guide
Feeling overwhelmed with upgrading your Chevrolet Equinox to LED? Worry no more! This complete guide has got you covered. From identifying the OEM halogen bulb sizes to selecting the perfect LED matches, we'll walk you through the entire process. With our comprehensive bulb size chart, you'll have the precise information you need for a hassle-free installation. Say goodbye to headaches and hello to a brilliant LED upgrade that will transform your Equinox's lighting game.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: H8
Front Turn Signal Light: 7443/7444(CK for 2013-2015)
Front Side Marker Light: T10/168/2825
License Plate Light: T10/168/2825
Interior Door Light: T10/168/2825
Back Up Light: T15/921/912
Rear Side Marker Light: T10/168/2825
Map Light: T10/168/2825
Dome Light: T10/168/2825
Trunk Light: T10/168/2825
Vanity Mirror Light: 31MM/ DE3175/ 6612F
You can try Lasfit LED bulbs on your Chevy Equinox. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam: LAplus H11
We would like to recommend Lasfit LAplus series H11 LED bulbs for your Low Beam Light. LAplus H11 LED bulbs are much brighter than halogen, 30W, 3000LM per bulb, 6000K bright white. New cooling system with a unique ball-bearing fan for heat dissipation makes the bulbs more lifespan.
High Beam: LAplus 9005
We would like to recommend Lasfit LAplus series 9005 LED bulbs to work on Equinox. 30W, 3000LM per bulb, 6000K bright white. They are built without an external driver directly plug and play. New cooling system with a unique ball-bearing fan for heat dissipation, and upgraded LED clip to ensure ultra-high luminous efficiency.
Fog Light: LDplus H11(Switchback)
The LDplus series is a special line of bulbs that can switch between white and yellow dual-color lighting. It is often used as fog lights to adapt to diverse weather conditions.
3000LM per bulb, 6000K for white light and 3000K for the yellow light. Strong penetrability in foggy day, snowy day, rainy day, and haze weather. The white light starts firstly, with a simple on-off-on toggle of your fog light switch to change the light from 6000K cool white to 3000K warm yellow light. Dual color fog lights can cope with more complex driving scenarios, without the need for more modifications. One bulb, two experiences, this will give you an extraordinary driving experience.
Front Turn Signal Light: T-7443D-(CK for 2013-2015)
Each bulb has 32pcs SMD 3030 LED chips (24pcs for amber, 8pcs for white). Built-in anti hyper flash Canbus system, specially designed for turn signals. Light up 6000K xenon white for parking lights or daytime running lights (DRL); 3000K flash amber for turn signal lights. Totally refreshed the tired and dim-looking lights with bright white DRLs and crisp amber turn signals. Intelligent Temperature Control System protects led bulbs against excessive current and overheating and ensures a longer lifespan.
Front Side Marker Light & Rear Side Marker Light: L-T10A(Amber)/L-T10R(Red)
800LM/set, much brighter than OEM halogen bulbs. It's necessary and easy to achieve to add a modern appearance to your truck by replacing stock halogen bulbs with this LED bulbs. No need any modification, just for plug and play installation.
License Plate Light & Interior Door Light & Map Light & Dome Light & Trunk Light: L-T10(White)
800LM/set, 6000K pure white. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Back Up Light: L-T15(White)
1400LM/set. The bulbs redesign distribute light in perfect direction, most notably improving the side and rear-ward spread. Clearly notice of the object as you back up and offer an excellent brightness inside the vehicle! Plug and play design.
Vanity Mirror Light: L-31MM
6000K pure/ cool white light. Festoon bulb. High quality 3030 SMD LED chips. 1.22'' in length, 0.47'' in width. Non-polarity design, plug and play. Efficient aluminum heatsink system for safe installation and usage.
LASFIT
Jan 2, 2024 8:33 PM
LASFIT
Colorado
Dec 21, 2023 10:12 PM
LASFIT
Dec 20, 2023 10:24 PM
LASFIT
Colorado
Nov 21, 2023 12:45 AM
LASFIT
Sep 5, 2023 9:30 PM
