2010 equinox sway bar shifting
#11
You can't weld on a sway bar because the heat makes the metal brittle. This makes the sway bay less flexible and more prone to breaking. A sway bar cannot function properly if it cannot flex.
#12
This would be two quick shots and would not make the metal brittle...they are surface welds. Hot Rods with I beam chassis' have had similar welding done on their entire length in order to box in the frame. Welding on the washer is much less intrusive.
Outcastz89
October 30th, 2008 11:08 AM
