2011 Equinox battery drain
Battery was tested and just had alternator replaced monday. As I was resetting the clock the vehicle seemed to lose power and now it wont start?
When you say you lost power, do you mean nothing works? Do you get lights on the dash? Does the horn work? Do the lights come on? Probably a loose connection somewhere. Check your battery cables and grounds.
Rico215
August 29th, 2018 12:39 AM
Flyingfox
August 22nd, 2017 2:11 PM
