Chevrolet Equinox
Platform: Theta
2011 Equinox Stabilitrak issue and electrical issues
Old Feb 21, 2018 | 10:47 PM
Gmoney316's Avatar
Default 2011 Equinox Stabilitrak issue and electrical issues
My 2011 Equnix has been running fine for a while but the other morning I tried the remote start. Car didn’t start so I went to check it and the remote wouldn’t work. So put the key in the ignition which was then stuck and wouldn’t turn all the way back. I popped the hood and the electric cane back on without me doing anything. Then as I was leaving work later in the day, the radio cut out and the message Service Stabilitrak came up but then disappeared. When I got home, went to turn the car off and it lost all power again. Key was stuck on the ignition as well. After about 2 minutes the power cam back. Has anyone else experienced this? Could it be that the 80amp mega fuse is going bad?
Old Feb 22, 2018 | 1:18 AM
ruley73's Avatar
These are all telltale symptoms of low voltage. Inspect the connections at your battery terminals, and get your battery & alternator tested. I'm thinking your battery needs to be replaced, but further troubleshooting is needed.
