Chevrolet Equinox
Platform: Theta
2013 equinox door ajar indicator
Old Sep 8, 2019 | 8:49 AM
rodneykeough@gmail.com's Avatar
Default 2013 equinox door ajar indicator
Last week I had the rear drivers side door open indicator came on and won’t go off. Also the power window won’t work from either to rear door switch or drivers door switch. I am thinking it may be a bad ground but don’t know how to troubleshoot. Does anyone have a wiring diagram or fix for this problem before I start to buy parts. Thank you
Old Sep 8, 2019 | 1:06 PM
check the wiring loom from the b-pillar into the l/r door. constant flexing from opening and closing can break the wires at the flex point. pull the rubber loom back.
Old Sep 9, 2019 | 5:59 PM
No appearance of worn or broken wires. After further investigation here are some more details. The window will not go down (or up) with either the back door button or the drivers button. I also swapped the rear window switches with and the result was the same. I also noted that when the windows down/up switch was unplugged from the rear passengers door it showed open on the dash. Once plugging in the switch it went away. I am now trouble shoot a window switch issue as opposed to latch actuator switch in that door. Are there any electrical schematics that would help me trouble shoot power paths.
Old Sep 9, 2019 | 7:14 PM
if you can remove the door trim panel....check for power and grd to the window motor when the switch is in the up and down position. if you have power and grd...the motor is nfg. if you don't have power...the wiring, switch or module must be faulty.
Old Sep 12, 2019 | 4:06 PM
No power from either rear switch or driver side switch. But power to the switch. Would you have a schematic so I could trouble shoot to the source
MG402424
Jul 27, 2019 7:58 AM
icemanthe1
Jan 13, 2017 12:05 PM
06EquinoxToSilverado
Oct 1, 2014 6:38 PM
Oct 1, 2014 6:27 PM
bluemoon
Uplander
Mar 8, 2013 9:04 AM
