Chevrolet Equinox
Platform: Theta
2014 Chevy Equinox Motor Swap
Old Feb 25, 2023 | 4:51 PM
KingOfHarts76's Avatar
Default 2014 Chevy Equinox Motor Swap
Had a motor swapped into my 2014 Chevy Equinox (2011). The coolant temperature sensor keeps failing. What am I doing wrong.
Old Feb 25, 2023 | 10:31 PM
keeps failing means what? If you mean a dtc keeps setting; post the code. a fault in ect system can only be in the sensor, wiring or computer.
your first post; so in the future post questions in the equinox section not the welcome area.
Old Feb 25, 2023 | 10:38 PM
[QUOTE=tech2;488017]keeps failing means what? If you mean a dtc keeps setting; post the code. a fault in ect system can only be in the sensor, wiring or computer.
Code P0128. Coolant Temp Sensor has been replaced-Codes reset then Temp gauge works for awhile as well as A/C then it fails.
Old Feb 26, 2023 | 9:07 AM
Welcome to the forum. Moving to the Equinox section.
Old Feb 26, 2023 | 10:05 AM
[QUOTE=KingOfHarts76;488018]
p0128 is a thermostat rationality code...when it sets the pcm detects the engine isn't coming up to temp in a set run time. If this is the only dtc and you have zero coolant temp sensor codes; replace the thermostat...its stuck open.
corvairbob
Feb 14, 2023 8:08 PM
Jschurter
May 15, 2022 3:57 PM
Aaron Dosentcare
May 10, 2019 10:56 AM
Shaketsha
Apr 2, 2018 5:19 PM
JeffWashington
Dec 10, 2016 9:48 PM
