Chevrolet Equinox
Platform: Theta
2018-2020 Chevrolet Equinox LED Upgrade Bulb Size Guide
Old Dec 26, 2023 | 9:29 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default 2018-2020 Chevrolet Equinox LED Upgrade Bulb Size Guide
Craving a flawless LED upgrade for your Chevrolet Equinox? Look no further! This comprehensive guide is the secret ingredient to achieving illumination perfection. The key ingredient is identifying the OEM halogen bulb sizes for your Equinox, as the right LED matches ensure a seamless plug-and-play installation. With our convenient bulb size chart encompassing all halogen lights from 2018 to 2020, you'll have the precise LED bulb sizes that align with your halogens, giving your truck a jaw-dropping LED transformation. Follow our expert tips to whip up an LED upgrade that will elevate your Equinox's lighting capabilities from lackluster to extraordinary.
Low Beam & High Beam: 9012
Fog Light: H8
Front Turn Signal Light: 7443/7444
Rear Turn Signal Light: 7440NA
Brake Light: 7443/7444
License Plate Light: T10/168/2825
Back Up Light: T15/921/912
Tail Light: T10/168/2825
You can try Lasfit LED bulbs on your Chevy Equinox. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam & High Beam: LAplus 9012
The specialty of the 2018-2020 Equinox is that its low beam and high beam share one bulb. During the upgrade process, we recommend the LAplus 9012, which has 6000K bright white light, 30W per bulb, and 3000LM light output.
With LAplus 9012 LED conversion kit, the installation is pretty straight forward. The mounting collar is adjustable for freely rotate. Free to adjust the socket until it shines the perfect beam pattern.
New cooling system with a unique ball-bearing fan preventing the driving from the loud noise from the cooling fan, all-in-one compact aluminum design brings better heat dissipation than common plastic design, and intelligent IC make sure the LED conversion kits last longer.
Fog Light: LDplus H11(Switchback)
The LDplus series is a special line of bulbs that can switch between white and yellow dual-color lighting. It is often used as fog lights to adapt to diverse weather conditions.
3000LM per bulb, 6000K for white light and 3000K for the yellow light. Strong penetrability in foggy day, snowy day, rainy day, and haze weather. The white light starts firstly, with a simple on-off-on toggle of your fog light switch to change the light from 6000K cool white to 3000K warm yellow light. Dual color fog lights can cope with more complex driving scenarios, without the need for more modifications. One bulb, two experiences, this will give you an extraordinary driving experience.
Front Turn Signal Light: T-7443D-CK(Switchback)
Each bulb has 32pcs SMD 3030 LED chips (24pcs for amber, 8pcs for white). Built-in anti hyper flash Canbus system, specially designed for turn signals. Light up 6000K xenon white for parking lights or daytime running lights (DRL); 3000K flash amber for turn signal lights. Totally refreshed the tired and dim-looking lights with bright white DRLs and crisp amber turn signals. Intelligent Temperature Control System protects led bulbs against excessive current and overheating and ensures a longer lifespan.
Rear Turn Signal Light: T-7440A(Amber)
24W/bulb, 2300LM/bulb super bright amber light. T series turn signal light is built-in Canbus resistor system, anti hyper flash, error-free, no error message. Plug and play, no need resistor, no flickering. Totally refresh the tired and dim looking stock lights. Intelligent Temperature Control System protects LED bulb against excessive current and overheating and ensures a longer lifespan.
Brake Light: T-7443R(Red)
15W/bulb, 700LM/bulb brilliant red light. This is an upgraded version with built-in CANBUS system to prevent error code and odd flickering. It's very easy to change the stock bulb to LASFIT LEDs. You will get a new look on the brake light with T series LED red brake light.
License Plate Light & Tail Light: L-T10(White)/L-T10R(Red)
800LM/set. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Back Up Light: L-T15(White)
1400LM/set, 6000K bright white. Lasfit uses high power 3030 SMD LED chip to produce peak brightness output and built-in Constant Current IC driver to ensures reliability. Equipped with CANBUS system, will not cause "lamp out" errors. Plug and play design.
Old Nov 14, 2024 | 4:19 PM
belizean501's Avatar
Thank you for this. Im new to the Equinox forum. What you guys think about the brand Auxito Led?
Old Oct 13, 2025 | 9:56 AM
HRPuffnstuff's Avatar
I use both LASFIT and AUXITO bulbs. In my 2018 Equinox the AUXITO 921 reverse lights do not work and will stay on constantly so I ordered the LASFIT 921 T15 CANBUS W16W error free bulbs. Their red CANBUS 7440 with resistor brake light/turn signal works fine as do their 194's which I used for the plate lights and the red version for the rear side marker light.
LASFIT is pretty good about letting you know what vehicles their bulbs work in. I've used their bulbs in other vehicles and they've been very good as have the AUXITO's.
LASFIT
Dec 13, 2023 10:29 PM
LASFIT
Nov 22, 2023 9:53 PM
LASFIT
2014 - 2018 (GMT-K2)
Sep 7, 2023 8:32 PM
Alan D Learned
2019+ Silverado (GMT-T1)
Dec 20, 2022 4:56 PM
Satyr
Feb 7, 2014 8:49 AM
