Chevrolet Equinox
Platform: Theta
2020 Equinox Lift Points
Old Dec 29, 2020 | 4:23 PM
jwh's Avatar
jwh
Default 2020 Equinox Lift Points
Hi,
New to the forum I have a 2020 Equinox I would like to use my quick jack for oil changes and looking for the lifting points, no luck finding anything in the owners manual anyone know where the lift points are ?.
Old Dec 30, 2020 | 2:59 AM
oilcanhenry's Avatar
Originally Posted by jwh
Hi,
A set of ramps are going to be better than using a jack and bending up your metal. Besides that it will give up a chance to
observe any other problems under your Chevy.
Old Feb 3, 2021 | 8:44 PM
HerveVR's Avatar
When looking under the side lower panel( plastic), you will find a square dent in the plastic about 8 to 10 ins behind the front end offront door and 8 to 10 ins ahead the ahead the rear end of the rear door.
Good to know if you have to change a flat tire on the way.
Have a successful search.
Old Jan 14, 2025 | 3:19 PM
Trowdiant's Avatar
I want to use your QuickJack for oil changes, super handy. For your 2020 Equinox, the lifting points are usually located around the car’s frame near the front and rear axles. You’ll want to look for the spots on the frame that are solid and flat, not the body parts like the plastic covers. I know it’s a bit of a pain finding info in the manual, so if you’re still not sure, a good tip is to check out car ramps nz for some visual guides.
dsm600rr
Oct 31, 2020 11:09 AM
tiggeri1p
Oct 30, 2019 9:28 AM
Aaron Dosentcare
May 10, 2019 10:56 AM
arifakhtar2004
Jun 9, 2017 7:52 AM
parentsmag
Jan 13, 2010 8:57 AM
