Chevrolet Equinox
Platform: Theta
Accessory Power Outlet
Old Aug 9, 2017 | 12:42 PM
Kim Hodge's Avatar
Wink Accessory Power Outlet
My Accessory Power Outlet in the front and back seat does not work the one in rear hatch does. I have check all fuses all are good and i even replaced to make sure. I used a power checker and it said i have no current on the plug.
Old Aug 10, 2017 | 2:08 PM
ruley73's Avatar
What year is your Equinox? Did you check the fuses in both the interior and underhood fuse blocks? The power outlet in the rear is probably on it's own fuse, but the other two probably share the same fuse.
Old Aug 11, 2017 | 7:38 PM
Kim Hodge's Avatar
2005 I checked all fuses my book only show fuse under hood it doesn't have a fuse for the plug on the inside fuse box I check that one to
Old Aug 11, 2017 | 8:18 PM
ruley73's Avatar
Each of the accessory outlets has its own fuse. The outlet between the front seats goes to the 20A CIGAR fuse in the underhood fuse block. The outlet behind the console that faces the rear seat goes to the 20A AUX 1 OUTLET fuse which is also located in the underhood fuse block. Both of these outlets share the same ground connection; so if both the fuses are good then the ground connection is probably bad.
