aftermarket stereo issues?
I have an 08, and I had put in an aftermarket stereo. After that, I found out later on that the remote start does not work with an aftermarket stereo. Now I did order my stereo parts through crutchfield, and i did get Metra's GMOS-LAN-01 GM data bus interface through crutchfield. It was able to restore use of the chimes and on star (which my equinox doesnt even have on star). After installing all of this, I had no clicking noise for turn signals, and the remote start doesn't work. Any clues as to how to bypass the stereo on the remote start? I honestly could care less about the turn signal noises, but I would like the remote start to work. Thank you.
Try removing the integration module and see if it remote starts. The module may be throwing a code which is why its not remote starting.
Sounds like you have the wrong module anyways seing as though the signal don't work
ActiveMonkey
11
September 13th, 2008 4:26 PM
