Chevrolet Equinox
Platform: Theta
aftermarket wire harness not working
Old Sep 2, 2014 | 1:45 AM
Crucialtagz's Avatar
Default aftermarket wire harness not working
I have a 05 equinox and my factory CD player died....so I went and bought a scoshe gm 3000 harness for a pioneer head unit I got...I wired it up using bunt connectors
Plugged it up and it didn't come on....so I went and bought a Walmart harness wired it up...still the same problem...BUT (AND I KNOW THIS WASNT SMART)
BUT I CONNECTED THE 2REDS &THE 2 YELLOWS
TOGETHER AND IT WORKED...but IT WOULDNT SHUT OFF
WHEN I TURNED THE CAR OFF
DOES ANY ONE HAVE ANY IDEA WHAT I MIGHT BE DOING WRONG...
I checked all my fuses and did a voltage test...everything seems to b in working order
Old Sep 2, 2014 | 11:03 AM
There are two 12 volt lines going to the player. One is on/off with the key and the other is hot all the time. Possibly you these 2 reversed.
Old Sep 2, 2014 | 3:51 PM
I reversed them as well but still no power...someone at a local car audio shop said I might have to run a wire to the battery...but I don't wanna do it cuz I'm not certain...I'd rather have some one be more specific
Old Sep 2, 2014 | 8:59 PM
ruley73's Avatar
You're using the wrong interface. According to it's user manual, the Scosche GM3000 interface only works for 2007-2009 Equinox.
The correct interface from Scosche for the 2005-2006 Equinox/Torrent is GM16SRB, but it doesn't retain OnStar. You will not be able to walk into Wal-Mart and buy it. You'll need to go to Best Buy or a car audio shop to get it unless you order it from an online retailer.
You need the interface because a regular switched +12v lead is not used with the factory radio. Instead, the radio is commanded to turn on through a data connection with the BCM. The interface creates a switched +12v lead to use with an aftermarket radio.
Old Sep 3, 2014 | 5:47 AM
You should never run a power line directly from the battery without putting a fuse in the circuit. Anyway a line directly to the battery will not be switched. It will be hot all the time. You can use a line from another component in the car that is switched.
Old Sep 3, 2014 | 8:50 AM
Man you guys are the best...I thank u very much....thank you.thanku .thanku .thankuthanku
Crucialtagz
Sep 2, 2014 1:00 AM
saltylife1974
May 31, 2011 3:43 PM
tahoe05
Sep 7, 2006 1:30 AM
purfus
Jun 18, 2006 5:54 PM
