Chevrolet Equinox
Platform: Theta
Another problem for me
Old Oct 24, 2014 | 8:12 PM
garridd1972's Avatar
Default Another problem for me
My 2006 Chevy Equinox LT is doing something funny. The Low traction light is coming on, and when it does the car loses a little power for a while then the light gose out and the power is restored. The ABS and Traction Control lights are not coming on while this is happening and they are working fine. So what could be the problem for that?
Old Oct 24, 2014 | 9:56 PM
does it occur when you are accelerating from a stop?
any mismatched tires or tires on the drive axle with
uneven treadwear causing a possible tire circumference difference?
Old Oct 24, 2014 | 10:01 PM
Only when acclerating past 55 mph for a long period of time. It will cut off but also cut back on.
Old Oct 25, 2014 | 4:18 AM
Okay I thank you for that post. I did added a size a little bigger on the back versus the front. Will it have a really bad effect on that vehicle if I keep them on there to long?
Old Oct 25, 2014 | 8:12 AM
if you have an awd it will damage the transfer case. if you have fwd it will skew all the wheel speed sensor data which is used for traction control, abs and stability control.
you may have created the problem. put 4 matched tires of the same brand on the vehicle.
Old Oct 26, 2014 | 2:37 AM
Thank you very much, I did and it solved the problem.
Chevrolaid
Astro
Jul 6, 2015 10:35 PM
Chevrolet Forum News
Jan 14, 2013 7:38 PM
mrsmoos
Jul 8, 2008 4:18 PM
1hot650r
Jan 12, 2007 1:01 AM
Killglass
Aug 5, 2006 1:59 AM
