Battery
New User
Awaiting E-mail Confirmation
Battery
I want to replace the battery pack the car equinox 2007 3.4L 6cly FWD
What are the specifications for this battery. Ampere?
The battery capacity in terms of the amount of amps?
BCI group 47
650CCA
The OEM battery is an AC Delco 47-7YR. DO NOT install anything with a smaller rating than 650CCA. This is difficult because most popular brands only provide 600CCA in this size. Unlike most other vehicles, the charging system monitors the state of the battery and adjusts system voltage accordingly. Our Equinox often drops to 12.6 Volts while driving down the road - this is normal. Unfortunately, side effects of this are the blower motor doesn't blow as fast, windows don't go up & down as fast.
When this happens I've found that you can effectively override the system by manually turning on the headlights. The charging voltage will then slowly climb back up to 13.9V.
650CCA
kllawson
Avalanche
December 22nd, 2010 6:31 AM
Igotasilveradonstuff
December 8th, 2010 12:55 PM
Sirius018
July 17th, 2010 10:10 AM
