Chevrolet Equinox
Platform: Theta
Brake controller install.
Old Sep 2, 2020 | 8:19 AM
Rustydog's Avatar
Default Brake controller install.
2019 Equinox Premier 2.0 T with a factory tow package.. E-Trailer list the brake controller pigtail as unconfirmed for a 2019, I would think it would be the same as a 2018 Nox. Where is the factory brake controller connector located?
I would like to eyeball it prior to ordering.
Ken
Old Sep 2, 2020 | 12:35 PM
Gumby22's Avatar
Edit - I just realized I gave you the wrong info about brake controls. Sorry.
There should be a blunt cut wiring harness zip tied to the rear of the vehicle near the bumper. If there’s an existing plug, trace the harness from the plug and you should be able to find it.
Below is the wiring diagram for trailer controls.
Old Sep 2, 2020 | 3:24 PM
Rustydog's Avatar
Thanks for the wiring diagram it is a big help.. Looks like they don't use a connector in the front just discrete wires that will mate with a standard Tekonsha pigtail.
I believe the factory installed 7 pin connector is prewired. Will check it out after I get the under dash installed.. Your help makes it easy...
Ken
Old Sep 2, 2020 | 5:49 PM
Gumby22's Avatar
If there’s a 7 pin plug from the factory then all you need to do is find the blunt cut wiring in the harness and splice it with the wiring for your brake controller. It should be pretty straightforward.
Old Mar 26, 2021 | 7:59 PM
Jase47's Avatar
Did you ever figure this out? I have a 2020 Equinox that I'd like to wire in a brake controller. It's proving more difficult than I thought. Thanks.
Nick Willi
Colorado
Dec 29, 2019 11:36 AM
thomas hanley
Jun 16, 2018 3:00 PM
ramon
Colorado
Mar 16, 2016 6:25 PM
mvusse
Jul 4, 2014 9:49 AM
T-bone
Aug 29, 2011 1:16 PM
