brake light switch
My left and right brake lights won't light when i press the brake. changed out all bulbs and replaced the fuse. wiring looks good. Is it the brake light switch? Thats the only possible item i know left. Any help would be appreciated.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> dallasp,
It's a possibility. You may want to have a certified technician take a look at it to be sure.
Keep us posted.
Louis
GM Customer Service
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
Keep us posted.
Louis
GM Customer Service
I am having the same problem. All three of the brake lights are out. We changed the bulbs and fuses. Is it the brake light switch? Where is that located? Please help!!!
The top brake light illuminates just fine. It is an 05. The brake light switch is located underneathe the steering column. If you follow the brake pedal arm up and remove the undercover you will see it. Im just not sure how to remove it.
I've attached some wiring diagrams below.
2005 Exterior lamps 1of2.pdf
2005 Exterior lamps 2of2.pdf
I have the identical issue. Left and right brake lights out, but top brake light works. I was curious if anyone has discovered the cause? (2006 LS). I've checked blubs and fuses. Any help or information would be appreciated greatly.
The issue with mine ended up being the brake light socket. An easy repair since the only thing you have to do is remove the brake light assembly and then disconnect the plug/socket and replace. Check and see if you have any burns or discoloration inside the sockets...plastic melted over the 2 contact points inside. If not that then it could be the brake light switch which is a harder repair from what i understand.
Official GM Rep
Consider checking out GM Parts Direct: Your direct source for Genuine GM Parts for the available parts.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
*General Motors neither endorses nor maintains these sites and will not be responsible for any of its contents.
jimmys57chevy
August 22nd, 2012 8:45 PM
jrsavoie
July 19th, 2012 2:36 PM
beckya99
July 12th, 2011 12:29 PM
honda450
December 3rd, 2007 3:41 PM
