Chevrolet Equinox
Platform: Theta
Old Jul 22, 2015, 2:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission
Print Wikipost
complete transmission fluid change
Old Jul 18, 2017 | 11:19 PM
  #41
ThePrince74's Avatar
I have a Chevy Equinox 05 AWD. How different is to drain and flush, and add transmission fluid to my car?
Old Jul 19, 2017 | 9:18 AM
  #42
ruley73's Avatar
The process is the same for your Equinox. It would be a good idea to change your transfer case fluid too while you're at it.
Old Jul 20, 2017 | 10:07 PM
  #43
7474's Avatar
Originally Posted by tech2
i didn't even know that i said that. thanks for pointing that out.
So, asian held a gun to Chevy's head to use their product? Why would I blame the company that made the transmission? GM wasn't forced to use it, they chose to use it. So, the blame lies with them.
Old Jul 20, 2017 | 10:08 PM
  #44
7474's Avatar
gm put the aisin built trans in this vehicle...aisin is toyota owned...so complain to the right company.
Old Feb 8, 2018 | 11:37 PM
  #45
Xplicit's Avatar
Default Transmission
I got a 2007 eqinox .What about the bolt under the battery holder.. Is it safe to add transmission fluid in there or not..
Old Feb 9, 2018 | 3:46 AM
  #46
oilcanhenry's Avatar
Originally Posted by ruley73
I think most will agree that getting all of the old fluid out is important. It's the method that this is done that everyone has different opinions about. Just to clarify, there is a difference between a flush and a fluid exchange.
During a flush, fluid is pumped through the transmission by a machine. Whether this is good or bad depends on who you ask, but I myself don't support it.
In a fluid exchange the vehicle is started so the transmission pumps the old fluid out of one of the cooler lines while fresh fluid is added.
I dont either. Amazon sells a gallon of GM ATF VI for 35 bucks. I'll just change the fluid more often since I cant change the filter anymore.
Amazon Amazon
Old Feb 9, 2018 | 8:25 AM
  #47
https://www.amazon.com/ACDelco-10-93...smission+fluid
just don't put dexron vi in you equinox or the asin trans will die.
Old May 19, 2024 | 11:28 PM
  #48
Tallguy6ft7's Avatar
Hey I know this is old thread but hoping to get someone to reply. I have an 05 equinox AWD with approximately 160k on it. Transmission line blew got a fix to that but issue is my fluid is pretty black. I checked the levels by dropping the motor mount bracket (which came out super easy surprisingly) but the level is showing at the almost hot level when the car is off. I know the normal thing to run the transmission and get up to temp and so on. I guess can I run the engine on the ramps while the motor mount is disconnected? I have it supported with Jack and some wood block at this time but don't want to start the engine and break something. I've seen everyone say to do the drain and refill and so on but idk what to do at this point. Any and all answers would be greatly appreciated! Thanks
Old Feb 1, 2026 | 1:12 PM
  #49
Ed Toler to's Avatar
Default Transmission fluid AF33-5 or T-IV where to buy
Where can I buy this type of transmission fluid I've looked at auto zone and they don't know what I'm talking about and I checked Walmart and they don't have it either.
newcster68
Apr 10, 2021 5:59 PM
dhuberasu
HHR
Feb 13, 2015 1:56 PM
DeHartShadow
Mar 28, 2010 10:10 PM
Big D
Mar 27, 2009 1:19 PM
blazerman
Apr 5, 2008 11:08 PM
