Chevrolet Equinox
Platform: Theta
Coolant Bleeder valve on 2006 Equinox
Old Jun 23, 2022 | 4:34 PM
Jidosha's Avatar
Default Coolant Bleeder valve on 2006 Equinox
I broke off the top of the coolant bleeder valve on my 2006 Equinox with the 3.4L engine. The part is NLA from GM and I can't seem to find any aftermarket replacement. I can't be the only one with this problem. Has anyone found a replacement other than the junk yard or some other solution? Thanks.
Old Jun 24, 2022 | 7:22 PM
ruley73's Avatar
Replace the whole fitting. Dorman p/n 626-530 is a direct replacement for the OEM fitting (GM p/n 12582446). It's only $18 on Amazon right now. A local auto parts store might have one in stock for around $25.
Old Jun 26, 2022 | 1:46 PM
Jidosha's Avatar
Thanks for the tip. I ordered it - hope it works out. I had been focused on finding just the valve.
Old Jun 27, 2022 | 5:37 AM
Gumby22's Avatar
Just FYI on options if a replacement can’t be located:
1) You can also crack loose the valve fitting to bleed the system. Loosening the fitting a couple of turns provides the same result by allowing the air to bleed out through the threads.
2) The fitting and valve screw are just brass, and assuming it’s removed without excessive damage, could easily be drilled and tapped for a replacement screw of just about any thread pitch.
Old Jun 27, 2022 | 1:25 PM
Jidosha's Avatar
Thanks. I knew that was an option, but really wanted a proper bleeder set up so the Dorman part swap looked to be the most cost effective. Will be doing it tomorrow.
ap4u06
May 27, 2022 12:12 PM
Hams1147
Dec 10, 2020 12:15 PM
cfrontz
Jan 10, 2016 11:15 AM
nealyf
Jan 7, 2015 11:51 AM
MR_EquIxNutz
Sep 24, 2008 3:47 PM
