Chevrolet Equinox
Platform: Theta
egr valve
Old Feb 12, 2017 | 7:25 PM
fredeunbehaun's Avatar
Default egr valve
I'm looking for the part number for an EGR valve for my 2010 equinox. The ABS and Stabillok lights just started coming on a few days ago. The mileage is around 70,000. For some reason the part number doesn't come up in a search for the 2010 model.
Old Feb 12, 2017 | 10:04 PM
vehicles with variable valve timing perform the egr function through vvt scavenging. So does it even have a egr valve?
what code is setting.
Old Feb 12, 2017 | 10:29 PM
ruley73's Avatar
The 2010 Equinox (both 2.4L and 3.0L) does not use an EGR valve. A new EGR valve wouldn't fix your problem anyways. A bad EGR valve as only causes the SERVICE TRACTION CONTROL/SERVICE STABILITRAK message on 2005-2009 Equinox w/3.4L engine. You'll need to get the problem properly diagnosed. The ABS light coming on means there is a fault in the ABS system. This could be something simple like a wheel speed sensor, or something more serious like a computer malfunctioning.
Without knowing anything else, I'm thinking you most likely have a problem with one of the wheel speed sensors. Relplacing the corresponding wheel bearing/hub assembly would probably fix it if that were the case.
