Electrical issue
I had a short out near the fuse panel. Seems as tho when the Sirius radio was put in, they tapped into the aftermarket sunroof wiring, which is connected the hot wire is connected into the number 8 slot, which is the dr/lock slot and the common is connected into the number 1 slot, which is for the sunroof. For some reason they left the hot wire exposed and it touched the ground. I checked all the fuses and they're all fine, but I still don't have a power to the sunroof, windows, and power locks. Any suggestions as to what the issue could be and how to fix it?
