Chevrolet Equinox
Platform: Theta
Garage Door Buttons Stopped Working
Old Feb 22, 2021 | 1:17 PM
LOyer's Avatar
Default Garage Door Buttons Stopped Working
On a 2021 Equinox, my interior garage door opener worked for the first 6 weeks. Then last week it stopped.
I have two separate hand-held remotes and both still work (fresh batteries).
I have erased the interior buttons (holding 1 and 3 down until blinking) and no fix. I have attempted to reprogram the interior buttons using the hand-held unit ....the red light goes on, then slow blinks and then nothing (it should go to a fast blink).
Is there a battery in the interior controller ? Any other ideas?
Old Feb 22, 2021 | 3:34 PM
no battery...its powered by the vehicle
does the garage opener (not the remote) need to be put into programming mode?
Old Feb 22, 2021 | 3:55 PM
LOyer's Avatar
If the hand held units ( two of them) work properly, it seems to me the problem is the Equinox controller brain isn't recording the appropriate code.
It did function when I first bought the car and stayed working (when programmed by the hand-held units) until just last week.
I think I may have to take the SUV in to the dealer for warranty work.
Old Feb 23, 2021 | 6:58 AM
OHHEY's Avatar
I had an issue with my garage door after installing LED light bulbs in the opener. Some type of RF thing. Did you recently install LED bulbs anywhere near the opener?
Old Jul 12, 2024 | 11:05 AM
duamondfigaro's Avatar
Since your handheld remotes are working fine, it’s probably not a battery issue in the interior controller—those usually don’t have separate batteries. You did the right thing by trying to reprogram it.
Old Jul 24, 2024 | 6:56 AM
One thing you might try is to disconnect the car battery for a few minutes and then reconnect it. This can sometimes reset the system. If that doesn’t work, it might be a deeper issue.
For more help, you might want to check out https://portlanddoorsandlocksguy.com/. They offer garage door repair and could give you a hand with this problem.
Christopher Sumrall
Jan 27, 2020 9:53 PM
trailbenz
Sep 26, 2018 12:21 PM
96DieselBurb
Mar 16, 2014 9:18 PM
raycer
Sep 17, 2012 2:51 PM
05 Z71
Oct 9, 2007 6:47 AM
