Headlight issue
I have a 2014 equinox. I noticed that the driver side headlight was out. Also noticed my driver side turn signal in the back not working shortly after(same day). The front driver side turn signal works but blinds faster then normal. Could both issues be related or coincidentally both bulbs went out same time. Possible fuse issue. I'm new to working on my own car. Please help
Thank you,
cutty91
Thank you,
cutty91
Check for melted wires leading to any of the fuses, and replace said fuses if necessary. Use a voltmeter to make sure that power is actually running to your headlights . If not, then the problem is in your wiring.
Michal B
Oct 25, 2019 10:28 AM
C3500
Jul 3, 2012 11:03 AM
