HELP!!!!! 2007 Equinox Power Steering
ok my power steering is out and i hear that it could possibly be the mega fuse i am going to my local dealership they have it in stock yet how do i know mine is blown and also should i disconnect the negative on the battery or will it be ok please help asap thanks
If your 80 Amp fuse was not the issue to the loss of your power steering try and wiggle the wiring on you Power steering motor and push in the connectors under the steering column. Do not know if it a temporary or a permanent fix. This might be a quick and easy fix.
If your 80 Amp fuse was not the issue to the loss of your power steering try and wiggle the wiring on you Power steering motor and push in the connectors under the steering column. Do not know if it a temporary or a permanent fix. This might be a quick and easy fix. https://youtu.be/e-jE_wxKOWY
I just joined so I could confirm that this actually worked for me! I was 99% sure it wouldn't do a damn thing. Hahaha I didn't feel any loose connections, but after wiggling the wires and connector the power steering works again. I only drove it for about 5 minutes, but so far so good.
RazzMaTazz
April 27th, 2015 9:47 PM
bobbygrady
August 14th, 2013 8:57 AM
cyberrkatz
January 31st, 2011 8:54 AM
