Chevrolet Equinox
Platform: Theta
HELP!!!!! 2007 Equinox Power Steering
Old Mar 15, 2010 | 10:06 AM
tdl5606's Avatar
Default HELP!!!!! 2007 Equinox Power Steering
ok my power steering is out and i hear that it could possibly be the mega fuse i am going to my local dealership they have it in stock yet how do i know mine is blown and also should i disconnect the negative on the battery or will it be ok please help asap thanks
Old Dec 31, 2018 | 8:56 AM
cmatson's Avatar
Tested the 80amp fuse on my 2007 Equinox it tested ok, my power steering is not working and is very stiff could this be the motor? I have no warning lights on
Old Feb 18, 2019 | 11:53 AM
Jesus Romero's Avatar
Default Solved! 08 power steering
If your 80 Amp fuse was not the issue to the loss of your power steering try and wiggle the wiring on you Power steering motor and push in the connectors under the steering column. Do not know if it a temporary or a permanent fix. This might be a quick and easy fix.
Old Jul 18, 2019 | 4:18 PM
deftone323's Avatar
Originally Posted by Jesus Romero
If your 80 Amp fuse was not the issue to the loss of your power steering try and wiggle the wiring on you Power steering motor and push in the connectors under the steering column. Do not know if it a temporary or a permanent fix. This might be a quick and easy fix. https://youtu.be/e-jE_wxKOWY
I just joined so I could confirm that this actually worked for me! I was 99% sure it wouldn't do a damn thing. Hahaha I didn't feel any loose connections, but after wiggling the wires and connector the power steering works again. I only drove it for about 5 minutes, but so far so good.
Old Jul 19, 2019 | 2:56 AM
I’m so glad it helped you and possibly saved you a couple dollars taking it to diagnose or even having a mechanic work on it only to tell you “If it's not this then it will be that” Honestly it’s been 6 months since I did this and I have not lost power steering, only twice the service stabiltrak light comes up but will usually turn off after I turn off the car and turn it back on. I would greatly appreciate it if you support my video and share it so it reaches people having this issue; i looked everywhere and nothing whatsoever was helpful.
joehenry005@yahioo.c
Feb 8, 2022 10:01 PM
dvickn4ome
Sep 27, 2015 2:42 PM
RazzMaTazz
Apr 27, 2015 9:47 PM
bobbygrady
Aug 14, 2013 8:57 AM
cyberrkatz
Jan 31, 2011 8:54 AM
