How do I disable to the start-stop system
My 2020 equinox has auto stop/start and I would like to permanently disable it. I know about the L and pushing the + button 5 times. I have seen on you tube a wiring harness called the eliminator. Would like to know more about it before thinking about getting one. Also harness called smart stop/start override module. Would like info on this one too. Any info would be appreciated.
I also saw on you tube a video on servicing the transmission on my 1.5L turbo. It showed a filler cap on top of the transmission. I don't see the filler cap on my transmission. Do I have one and if so where is it?
Thanks again! Bill
2020 Equinox 1.5L turbo
Thanks again! Bill
Thanks again! Bill
Thanks again! Bill
You'll likely need to buy a long funnel to refill it through the vent hole. The sight plug is usually an 11 or 12-mm plug on the driver's side. Turn your wheels all the way to the right or remove the wheel to access the plug easier.
Once it starts to flow out with new fluid, just cap it off with the plug. I think you have the 6T40 transmission, the same as my Malibu, so 4.5 quarts of Dex VI will be needed. The filter is way up in the transmission and not replaceable without breaking the transmission apart meaning a transmission overhaul. There is no such thing as non-replacement transmission "permanent" fluids, no matter what.
Thanks for the info Henry. Could you give me a location for the vent/filler hole.
Don't know which transmission I have and don't know where to find the info. I have looked everywhere I know for it'
thanks bill
thanks bill
oilcanhenry (June 20th, 2023)
Bill, If it's built close to my 2015 Malibu, the vent will be on the driver's side right on top of the transmission. It's way down there so you'll need one of those long black funnels to add the Dexron VI fluid back in. You just unscrew it by hand. I looked up your transmission and it should be a 6T40 like mine. I know it's a PITA but all the new cars, Chevy or not, seem to have eliminated transmission oil dipsticks on all but pickup trucks.
I must have a different transmission. All I can find on top of the trans is the arm for the shifter to hook to and a decal. I'll keep looking.
bill
bill
This Youtube video might help you, Bill:
Thanks for the video. I don't have a filler cap where the videos show. The linked youtube video title says for a 6T40 but the narrative by the guy says 6T70. Maybe I have a 6T70. Could someone tell me how to find out?
The following 2 users liked this post by tech2:
oilcanhenry (June 22nd, 2023),
ruley73 (June 23rd, 2023)
I watched the video and am sure my trans. does not have a vent/filler cap on top.
I will take a picture tomorrow and try to post it. Anyone know the max size for an image attachment?
