I need help with wiring.
I had to remove the drivers side headlight assembly on a 2010 Equinox LT to install an aftermarket unit. In the process I cut the wiring to the plugs on the wiring harness. I need to find out which wires go together when I install the new plugs being that the wires on both sides are different colors. Does anyone know which wires connect to which on the plugs?
I wanted to install a better wire harness because the original one looked corroded. The plug I cut is not the bulb plug, it's the plug that connects to the headlight unit. Because the wiring on either side of the plugs are different colors I just wanted to make sure I have the right wires connected to each other.
I would do that but my kid threw out the old plugs while cleaning the work area. So I have no type of guide as to what wire goes where.
Ouch! That would certainly throw a wrench in the gears. I should be able to fetch the wiring diagram you need after I get off work today.
These should have what you need.
2010_Equinox_headlamp_wiring.pdf
2010_Equinox_exterior_lamps_wiring.pdf
